October 18, 200917 yr comment_383142 hey I'm converting my ae71 to sr20 na just wondering if anyone had any good advice about the best way to go regarding wireing, mounts ect. any info would be great cheers Edited October 18, 200917 yr by vinny kain Report
October 18, 200917 yr comment_383213 welcome to the forum I might be able to help you with the mounts soon enough, wiring shouldn't be much of an issue try a few searches for this topic whats your location? Report
October 20, 200917 yr Author comment_383852 Hey, i have a s13 crossmember is it better to use that or modify the ae one. I'm in the adelaide hills how much would you be asking for the mounts? cheers mate Report
October 20, 200917 yr comment_383854 I wont have a price on the mounts till I make my first set. Using the S13 crossmember, the lower control arms or both totally messes up your steering geometry Report
October 20, 200917 yr Author comment_383859 oh ok is it very hard to modify the ae crossmember and are there any pictures out there on how to do it, which control arms would u advise using? thanks for the help mate. Report
October 20, 200917 yr comment_383864 well I don't see why you would have to mod it at all. With the mount design I have in mind you just bolt them to the SR block and then it uses the stock 4ac rubber mounts to the crossmember. Stock arms are fine or XT130 corona if you want -1 to -1.5 degree of camber which is excellent for grip. Report
October 20, 200917 yr Author comment_383868 when do u think u would have a set of mounts made though. I'm pretty keen to get mine underway this weekend mate. got the engine and box and ready to get started. what diff would u use as the is blown already and needs replacing and i may aswell use something a bit stronger. i couldnt find much info about the conversion on this site yet any advise where to look any other sites better for this topic? Report
October 20, 200917 yr comment_383874 look on ae86drivingclub forums an R31 is a popular conversion and I have done two myself, a third soon it seems. I am going to be a month or two yet so your out of luck. Report
October 22, 200917 yr Author comment_384399 hey does any one have any plans or photos of any engine and gearbox mounts if so it would be great Report
October 24, 200917 yr comment_384890 suspend the motor into place, make up some cardboard/MDF mounts and replicate with steel. Report
