Tham Posted October 19, 2009 Report Posted October 19, 2009 Can the battery mounting brackets for the KE70, 4K, be found anymore ? It is a not-so-common bracket, with a straight bar on top, screwed in with a nut at the front end near the grill, with a long rod screwed in the rear end, hooked at the chassis bottom below the battery tray. A nut tightens the top of the rod and clamps the battery down. Those univeral mounting brackets with two rods at each end, sold in auto parts shops, are not really suitable. My bracket is still usable, but the L-shaped metal plate which clamps the top edge of the battery is already corroding. Quote
Taz_Rx Posted October 19, 2009 Report Posted October 19, 2009 Put up a wanted add in the wanted section. You could also have a look for somebody wrecking a Ksev and ask them if they've got one. :) Quote
Evan G Posted October 20, 2009 Report Posted October 20, 2009 pfffttttttt brackets, just use huge cable ties! Quote
Medicine_Man Posted October 20, 2009 Report Posted October 20, 2009 pfffttttttt brackets, just use huge cable ties! Some people aren't dodgy and like to do things properly.. Quote
