October 23, 200917 yr comment_384574 Just a quick one Just wondering what causes a starter motor to start spinning but not engaging the flywheel when i connect battery i have checked for loose wires, blown fuse blah blah, starter is wired up fine, just main wire held on with a 12mm nut, and one 1 pin plug. Only thing stopping car from starting atm, Dan Report
October 23, 200917 yr comment_384575 Been there, done that. this is without a key even in the ignition yeah? The big fat wire held on with a nut was touching the body of the starter motor, which was completing a curcuit. Report
October 23, 200917 yr Author comment_384582 ahhhk, so if i undo the nut and move wire so its not touching anything, it should be fine? And does it go solenoid/nut/washer/fat wire/washer/nut? or doesn't it really matter? Report
October 23, 200917 yr comment_384583 ahhhk, so if i undo the nut and move wire so its not touching anything, it should be fine? And does it go solenoid/nut/washer/fat wire/washer/nut? or doesn't it really matter? Yep. Don't think it matter as long as it has the bit of insulating platic under the first nut. :lolcry: Report
October 23, 200917 yr Author comment_384587 ahwell, it all goes, got it in and nothing, realised previous owner by passed something with a relay, and one of the pins comes off. so put back on, pump accelerator twice. and it started first pop Report
