hey i was just wondering, i have a ke30 and need to convert to hydrolic clutch i was wondering if ae71 is hydrolic and will it fit into ke30 with minimal mods?
cheers
cheers
No it will not fit in to ke30 .just mod your original one .Just finished this on a ke55 barstard of a job :S .
But if you take your time and read up on it not to bad. Do a seach heaps of info on this.
I will put some pics up later of my convesion.
rob
aah sweet as.. cheers any info would be great.. i noticed the pedel is offset from where the hole is for the master cylinder when it goes in how did you get around that?
In my KE30, my mechanic used my KE30 pedal box, and got a T18 clutch pedal welded onto it. Than used a holesaw to cut into the firewall. It worked pretty well, but the position of the pedal itself could of been modified a little bit. Had to make a custom pushrod for the slave though, as the stock one was to short I think
Cheers Fusion
