ae95- wagon kid Posted November 8, 2009 Report Posted November 8, 2009 how hard is it to swap a 4afe out of a ae95 corolla what do i need apart from the engine I don't think i could swap it myself so would anyone be interested in a bit of cash for doing a swap cheers I'm in adelaide Quote
.T. Posted November 8, 2009 Report Posted November 8, 2009 so you want to fit a 4age into a ae95 correct?? if so, you need to source an ae93 4age, ecu etc. basically it will bolt onto the ae95 gearbox. you will need to use the donor ae93 front engine block mount (the mount that bolts to the drivers side chassis mount) . you will need to change the clutch plate or fit a 4agze flywheel/clutch arrangement. wiring will just plug up. an easy conversion T Quote
ae95- wagon kid Posted November 9, 2009 Author Report Posted November 9, 2009 so you want to fit a 4age into a ae95 correct?? if so, you need to source an ae93 4age, ecu etc. basically it will bolt onto the ae95 gearbox. you will need to use the donor ae93 front engine block mount (the mount that bolts to the drivers side chassis mount) . you will need to change the clutch plate or fit a 4agze flywheel/clutch arrangement. wiring will just plug up. an easy conversion T cheers is that the 100kw 4age or what one is it do you know how much i could pick all that up for and do you know anyone willing to do the swap for me I'm in adelaide can you suggest anyone who wants the cash and has the time an d experience cheers Quote
ae95- wagon kid Posted November 9, 2009 Author Report Posted November 9, 2009 Has anyone any experience about swapping engines out of a ae95 rolla i have heard a ae93 rolla engine fits is this the 100kw engine and if so hoe much could i get all the stuff needed for and how much to have it installed i have a hefty budget and can part with some cash pm me if you know what your doing and are interested have the time to do a swap or have the parts needed cheers Quote
RedKE30 Posted November 9, 2009 Report Posted November 9, 2009 Has anyone any experience about swapping engines out of a ae95 rolla i have heard a ae93 rolla engine fits is this the 100kw engine and if so hoe much could i get all the stuff needed for and how much to have it installed i have a hefty budget and can part with some cash pm me if you know what your doing and are interested have the time to do a swap or have the parts needed cheers You need to contact some places and find out the costs for yourself. Any estimates people give here could be way over or way under, just depends on what you find in your area. Quote
philbey Posted November 10, 2009 Report Posted November 10, 2009 I've merged your two posts, try not to re-post virtually the same question a day apart. cheers. Quote
.T. Posted November 10, 2009 Report Posted November 10, 2009 ok i can't do this conversion for you as i'm in vic, however it is fairly straightforward. you need to find a written off sx or a motor conversion from a sx corolla. you could get lucky & find one in a pick-a-part for about $200, but you are more likely to have to buy one from an importers for ~$1200. (& then source all the missing bits) then the fitting - if you can't fit it yourself, expect to pay a "professional" around $100 an hour to fit. then to finish it off legally, you should get it engineered - but that part is up to you. depending on the block on your 4ag, you may need to do some minor mods to the bellhousing, later blocks do not need any mods. suggest you look at toymods or twincam etc & see if you can find someone local to you prepaired to help you with your conversion T Quote
Instigator Posted November 10, 2009 Report Posted November 10, 2009 Given the amount of posts you've made asking the same question 3 differnet ways just give it up mate. If you can't even be bothered to do the research yourself you have no hope of being able to complete a conversion. You've been pointed in the direction of KEB11N already who's selling a complete engine/ecu/drivetrain 4agze for $3k. Don't think you will find a better deal for your money than that and if that's not for you then sell the car and buy something else already complete with your "hefty budget". I put a 20v in mine so I know it's not easy. I got a halfcut for $1250 which influenced my decision and I did all the work myself. Expect to pay thousands for a drive in drive out conversion (not including motor to begin with). Toyota quote 12 hours labour just to change a clutch so do the maths. It's not really the best engine choice due to the lack of torque. Quote
