My 12a Bridgie Ke30
some temporary panel/paint work to stop it rusting away ..
motor - 12a bridgeport, nikki 4 barrel, electronic dizzy
leads - 9 mil eagle leads
oil cooler- rx2 oil cooler
scatter sheild
rad fan
s1 radiator
rad hoses
belt, temp sendor adapter ect
coils - bosch gt40
new dipstick from mazda
driveshaft loop
engine rubbers - solid mount style
engine mounts - made by kiwi re
crossmember and gearbox crossmember
4 Puk clutch kit
engine loom - made by me
motor and s2 rx7 box ready for ins
brakes - s4 rx7 hubs
new braided lines and pajero master to suit new brakes
ke30 handbrake and s2 rx7 shifter
fc rx7 handbrake cable
wheel selection
i love tarmacs
interior - suede door skins, mx5 seats, evo 1 center console, digital speedo, tacho, smoked guages and a momo wheel
nice work mate, looks like your doing the conversion properly with all the supporting gear. Only thing i see breaking would be your diff, got any plans to upgrade?
Another rota rolla is never a bad thing
it got a hilux diff and i even have a spare head haha
:blush:
awesum work there!! great to see another rotor going into a corolla, you from nz yeah? still lots of rx3s and rx2s over there??? I'm from wellington last time i was there there were rotors every where!! haha love em, good luck with the hole project looks like you have it in control! wish i could say the same about my sr20 rolla hahahaha :blush: go the rollas!!!!
haha thanks :P yes there are quite a few old rotarys around here in auckland :D i think i was looking at the sr20der rolla just before in this section, looks like a big mission haha how much clearance you go between motor and firewall :blush:
also i need some help setting up my fueling, i have got a holley blue fuel pump and a holley reg, do i need to run a return line?... would i benefit from using the factory line as a return and upgrading the main line (if so what should i upgrade to size, rubber/metal ect) cause if I'm not mistaken my car does not have a factory return thanks
my engines not quite in yet just sitting waiting .... so much to do! haha but yeah don't think theres going to be much clearance there maybe 5 -10 mm if that,not to worry my pics are in the gallery under jdm55,,, yeah you should definatley upgrade your fuel line 8-10 mm should be plenty, use steel bundy line,should be able to get it at repco or a hose joint over there,can't remember if rotors use a return line been a long time since played with them,i think some where i read you can blank off the return on the carb if its not already got a blanking plate on it,??? not 100percent ,but your holley should do the trick , keep up the good work love to see pics!!!
Edited by guitar mad
actualy have you got any more pics of the front brakes and strut set up? still struggling to find a practical brake upgrade for my beast,any infos be great cheers
I'm going to be putting my brake hoses on in the next few weeks so ill get you some getter pics then :blush:
msn .. [email protected]
Edited by MZ ROLA
Nice work dude. I like the wheels too.
This thing looks like a load of fun, The FC callipers with the MC will make the car stop great.
