I have an ae94 corolla with the 4afe engine. The battery has never died or been hard to start up.
While driving (used to do this occasionally, but now much more frequently), the charge light comes on and all lights go dim inside and outside the car. It will stay on for a while then dissapear and lights will go bright again, tonight it was happening on and off in 1 second intervals.
what is going on guys? my guess is somehting is loose. Ive never worked with alternators, I'm fairly novice with cars. The only way i have learnt about mechanics is when something breaks, i ask around, look in workshop manual, learn how it works and use all ur advice to fix it.
Any help on things to check or look for would be greatly appreciated. thanks all.
Calam.
Edited by Calam05
  • 4 months later...
Calam.
most likely will be your regulator.. mine went on my 4A-FC a month or so ago, easy and cheap fix, just go to your local repco or autobarn they should have it in stock.. take bout 10mins or less depending on your knowledge of working on cars
