Unfortunately on a Toyota the throttle arm swings through the position where the shaft between the two choke linkages should go, so I can't run the stock choke cable and link the two choke systems.
I'm not keen to cold start the car every morning on one rich and one lean carb, so has anyone seen twin cables around recently, or the kit that turned one cable into two? Do companies still make cables? What do bicycles do for cables??
What are you other SU guys doing??
Edited by altezzaclub
Have a look under the bonnet of an old Torana, like the XU-1 model
post-1432-1258797821_thumb.jpg Up near the brake cylinder (top right corner)
First saw the set up at an "All Holden day" and wondered what it was. First thought it was a custom set up till i saw the same thing on some of the other cars that ran triple CD carbies (Constant Depression - eg SU's)
And by the looks of it pretty easy to dodge up
Yeah, that's what I was looking for! I'd seen single to double cable converters, but not for years. I didn't think about motorbikes/ATVs, as they all still run carbs and there is still a good industry making cables for them.
I've emailed a couple of places and will put up the prices when I get them.
