December 3, 200916 yr comment_395219 i believe my car is running like a bag of shit, so i changed the plugs for a new set. is 5.00KΩ to high resistance between ignition leads? thanks for any advice. (i left my workshop manual at work DOH!) Report
December 15, 200916 yr comment_398379 Hey mate, don't know if you have got an answer yet, but checking it with a multimeter won't show much, you need to use a high voltage leakage tester thingo :y: cause its over 15,000 volts going through the leads and a multimeter can't supply that. An auto elect joint will show you... Report
December 15, 200916 yr comment_398392 i believe my car is running like a bag of shit, so i changed the plugs for a new set. is 5.00KΩ to high resistance between ignition leads? thanks for any advice. (i left my workshop manual at work DOH!) Check out the Top Gun website. They've got all the info you need. Report
December 15, 200916 yr Author comment_398399 cheers fellas, it was all sorted the next day at work, and no 5k ohms isnt a high resistance between ignition leads Report
