Need Advice On Hardtop
help can anyone tell me how to remove the panel where the windscreen wipers are so i can clean it out and do some rust repairs
It doesn't come out sadly. You have to work through the small openings in the firewall. If it helps drop out the wiper arms and remove the motor.
Then stick a Vacuum up there
The only option is to unpick it with a drill (WINDSCREEN OUT) , or cut holes to access the section that needs repairing
it has no windows at the moment which is helping alot with repairs
