It doesn't come out sadly. You have to work through the small openings in the firewall. If it helps drop out the wiper arms and remove the motor.
Then stick a Vacuum up there
The only option is to unpick it with a drill (WINDSCREEN OUT) , or cut holes to access the section that needs repairing
it has no windows at the moment which is helping alot with repairs
