February 9, 201016 yr comment_412270 32_36DGV.pdf Hi all, I recently bought a second hand 32-36 DGV weber. The weber came partially re-kitted and I needed to put the rest together, so.....I thought it best to put it in with a carbi specialist. He looked over it and said that it was in good condition overall but the 2 venturi's were stuffed. He mentioned that as the venturi's tend to wear the housing that they sit in, they don't normally stock spare parts for the venturi's and I would need to buy a new weber. Can anyone please tell me whether this is true? I have rung around and had some difficulty even finding someone who can get them let alone someone who knows if they are even available. I have attached a copy of what I believe is the weber with the diagram and parts breakdown. Any thoughts? Report
February 9, 201016 yr comment_412314 32_36DGV.pdf Hi all, I recently bought a second hand 32-36 DGV weber. The weber came partially re-kitted and I needed to put the rest together, so.....I thought it best to put it in with a carbi specialist. He looked over it and said that it was in good condition overall but the 2 venturi's were stuffed. He mentioned that as the venturi's tend to wear the housing that they sit in, they don't normally stock spare parts for the venturi's and I would need to buy a new weber. Can anyone please tell me whether this is true? I have rung around and had some difficulty even finding someone who can get them let alone someone who knows if they are even available. I have attached a copy of what I believe is the weber with the diagram and parts breakdown. Any thoughts? I'm no carb expert but didnt think those had loose venturis like the dcd. Are you sure he didnt mean the throttle shafts and bushes? Report
February 9, 201016 yr Author comment_412318 I'm no carb expert but didnt think those had loose venturis like the dcd. Are you sure he didnt mean the throttle shafts and bushes? Nah mate, definately loose, the diagram item is 83, they just sit in. Report
February 9, 201016 yr comment_412321 Yeah they do have lose venturi's. This sounds really homebrand and hillbilly spec, but mine were also fairly lose. So i just got some lock tight out and put a tiny bit around the housing bits they sit in. Venturi's are now nice and tight :) Report
February 9, 201016 yr comment_412338 You guys are talking about auxillary venturis, Metal epoxy them in place. Report
February 9, 201016 yr Author comment_412342 You guys are talking about auxillary venturis, Metal epoxy them in place. That's great but where do I get replacement ones? Report
