February 15, 201016 yr comment_413803 hey guys probably a bit of a stupid question but does a t18 diff assembly bolt straight in to a ke70 or do i need the t18 tail shaft as well or do i have to customize stuff???? any help would be appreciated cheers :) Regards Mike Edited February 15, 201016 yr by Cream Dream Report
February 15, 201016 yr comment_413807 Need a T18 rear half shaft. Other than that it bolts in quite well Report
February 15, 201016 yr Author comment_413832 Need a T18 rear half shaft. Other than that it bolts in quite well sweet i might have to go grab this one then do i need all the arms and shiz from the t18 as well or do the ke ones bolt on to the t18 diff? cheers Report
February 16, 201016 yr comment_414308 link bars are all the same, shocks bolt into the same place, brake lines have all the same connections, it even has the same spring platforms. It's just the tail shaft that is different where it bolts onto the diff flange. Report
February 18, 201016 yr comment_414748 BTW, If your keeping the K motor, I'm fairly sure the rear piece of the T18 shaft will not bolt to a KE70 front half. Totally different diameters. You'll need a full tail shaft and have to swap the front yoke off the KE70 to the T18 shaft. Report
