4age Webers
Can any one give me venturi (choke) size there running on there 4ages.I have 45 dcoes ,just a bass line setting to get it running.
From what i can work out 36mm ventures,145 main ,f16 e tubes,200 air corrector.idle ??
Just till i get it to the dyno .But the closer i can get it the better.
Am i close ??
cheers rob
IIRC the correct size is 32mm, I did have a website I used but I can't find it at the moment, I also used the a weber carb book, I will try to find the website and post it up.
Sorry the info I posted was for when I was originally going to run the 40's, It is 36, On a 4age running 40's it is recommended to use 34's, I'm pretty sure my old carby 4ag is running pretty good on the 45's.
Here is a website that gives basic info:
http://www.racetep.com/webercarbjet.html
Thanks trev ,i will try it with 36 s see how it works :)
cheers rob
nice information as I'm just in the process of same sort of set up 4age and twin 40
Edited by twisted2
