Are There Any Throttle Bodies That Are Interchangeable With A 4afe One
i need a much larger throttle body are there any toyota or other ones that fit or do i need one engineered
cheers
Wait, I'm curious, why do you need a much larger throttle body?
Your intake manifold will likely still restrict flow if you're going for big numbers, which I'm guessing you arent.
Edited by KENut
I'm porting the head and i want a bigger throttle body because stock ones r shit and are restrictive
so do you know where to get one or not???
did you try googling it?
Edited by Evan G
its a 92 so the old one
would a new one be better i can get one of a 2001 4afe or could a holden one work i have a few around the place
and i tried googling it
came up clean seems everyone uses stock one
I am not 100% sure, The best person to speak to about 4afe's is Ian (hiro protagonist), I presume you can you the later one.
