Window Seals Bad Need To Find Replacements
Hi all!
I have bad seals and rubber on my windshield , rear window. My front windshield is cracked and needs replacement also.
I live in washington state and I know some of these parts aren't even manufactured anymore.
Does anyone know someone or a business that can fabricate new seals or rubbers? Any recommendations for aftermarket replacements would be fantastic.
My baby is a little ke30 2d sedan.
I really appreciate any help,
Mike
Problem is those ones are coming from Thailand and keep getting a bad review here.
I would suggest
http://www.scottsoldautorubber.com.au/TOYO...0KE30-35-36.htm
Costs more, but the extra money is worth the extra life you will get from it.
Thanks Silverra! I emailed Scott through the weblink above. So I have 2 fail points, the seals and the moulding are bad. www.toyodiy.com lists the moulding parts. I went to a local toyota dealership and they said that these parts aren't manufactured anymore and that it would be impossible to source. The parts guy didn't seem very interested to offer any assistance so I'm not sure if he was just being lazy and blowing smoke or if he was being serious.
Any thoughts on where I could locate new or aftermarket moulding ? These are the parts for OEM below;
Rear Window Moulding parts
75571 MOULDING, BACK WINDOW, OUTSIDE UPPER
75571‑12090 KE3*, TE31, 37.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $29.09
75572 MOULDING, BACK WINDOW, LOWER
75575‑12040 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $25.62
75575 MOULDING, BACK WINDOW CORNER, UPPER RH
75581‑12010 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $7.13
75576 MOULDING, BACK WINDOW CORNER, UPPER LH
75577 MOULDING, BACK WINDOW CORNER, LOWER RH
75543‑12010 KE30, TE31.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $6.11
75578 MOULDING, BACK WINDOW CORNER, LOWER LH
Windshield moulding parts;
75531 MOULDING, WINDSHIELD, OUTER UPPER
75531‑12120 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $29.09
75532 MOULDING, WINDSHIELD, LOWER
75535‑12050 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $21.65
75533 MOULDING, WINDSHIELD, OUTSIDE RH
75533‑12140 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $14.08
75534 MOULDING, WINDSHIELD, OUTSIDE LH
75535 MOULDING, WINDSHIELD CORNER, UPPER RH
75541‑12050 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $4.39
75536 MOULDING, WINDSHIELD CORNER, UPPER LH
75537 MOULDING, WINDSHIELD CORNER, LOWER RH
75543‑12010 KE3*, TE3*.. -KE30LKBK, TE31LHBA, 31LHBFA 1 $6.11
75538 MOULDING, WINDSHIELD CORNER, LOWER LH
Thanks again for everyones help I really appreciate the responses! This community rocks!
What do you mean by moulding? The chrome strip that runs through the centre of the rubber and acts as the locking strip?
If that is what you mean, Scott's sells that too.
Not sure if they sell the corners as well, you might have to use what you have.
