May 19, 201016 yr comment_438711 would it match up? or do i have to get an apron from a flat front cheers Report
May 19, 201016 yr comment_438750 pretty sure you need an apron from a flat front to fit the guards Report
May 19, 201016 yr comment_438763 yeah you need the apron from the flat front. the slanty front sits out a fair bit further than the flat front, and the slanty front apron has these extensions that push it further away from the radiator support. the apron prolly sits around 100mm further out than the flat front one. not sure if you can modify the slanty front one to work, unsure what happends at the guard ends, id say it would be different though. Report
