May 22, 201016 yr comment_439237 hey guys will ann ae86 pedal box bolt straight in to my ae71 are the mounting bolts in the same place need to know ASAP cheers Regards Mike Report
May 22, 201016 yr comment_439249 Totally different animal. they're a separate pedal, not 1 piece like an AE71 Report
May 22, 201016 yr Author comment_439279 Totally different animal. they're a separate pedal, not 1 piece like an AE71 what bout just the master cylinder? Report
May 22, 201016 yr comment_439284 You would need to mount the clutch pedal mount, which will most likely require re-drilling or flaring a hole, then bracing it as it will be a bit floppy. Then you would use the pedal assembly from an auto ae71 with the pedal installed from a manual ke70 brake pedal, so its not double width. It can be done, its not super hard, but if you've never fabricated anything don't attempt it. Report
May 22, 201016 yr Author comment_439354 cheers for the info fellas i gave it a crack any way the didnt change the pedal box just changed my old ae71 maser with a Ae86 master went straight in with no mods needed after a of bit of adjusting and a shit load of bleeding she's all sweet now :D Report
