May 28, 201016 yr comment_440825 Hey guys, go to set the timing on my car and after i drive it for say....10mins, the timing goes from ~8deg right up to 12deg :blinks:, what do i need to replace now haha Report
May 29, 201016 yr comment_440872 Sounds like your dizzy has a sloppy shaft or advance plate thingy. Check if theres play in the dizzy shaft Report
May 29, 201016 yr comment_440895 Try marking the dizzy & block with white paint (typing whiteout) and see if the dizzy turns when you drive. That wll tell you if its internal or external on the dizzy. If its turning its dead easy, a clamp problem. If its internal you'll have to strip the dizzy and look at its operation carefully. The advance plate as KENut says, or inside the vac advance diaphram. Report
May 31, 201016 yr comment_441241 Wait a minute - are you running the car at the same rev's both times? Because if you tune it while it's cold and at low revs, then come back 10 minutes later and the idle speed has increased, you're dizzy may just be advancing normally. Secondly, if you have slop in the dizzy, you wont find it just advances 4 degrees. You can pick sloppy timing chains etc because when you are trying to time it the mark jumps around all over the place. Edited May 31, 201016 yr by philbey Report
