RND.IGO Posted May 30, 2010 Report Posted May 30, 2010 Hey guys just wonderin what auto will bolt up behind 4age.. 4ac should right ? how would they hold up be 250+hp any thing else? Quote
rb20 rolla Posted May 30, 2010 Report Posted May 30, 2010 (edited) Hey guys just wonderin what auto will bolt up behind 4age.. 4ac should right ? how would they hold up be 250+hp any thing else? if you beef it up a bit it should hold 250hp i was going this way at first but my gearbox guy said that's about it and i wanted one to hold more then that. as for the box bolting up if the mannal ones do then the auto one should, you just have to see if the flex plate and converter from a fwd are the same bolt patten as a rwd one.. Edited May 30, 2010 by rb20 rolla Quote
towe001 Posted May 31, 2010 Report Posted May 31, 2010 Hey guys just wonderin what auto will bolt up behind 4age.. 4ac should right ? :D They both share the same block to bellhousing bolt placements. A40 auto from the top of my head. Don't know how they'll go with the horsepower and i can't say with getting it tricked out either. But if you can get the bellhousing modified or something customized - go for the trimatic. If they can be tricked out for work behind a hotted up v8, a four banger would be easy stuff. Quote
