May 31, 201016 yr comment_441337 hey guys i have been racking my brain trying to choose between 20v or sr20 and i have decided to go sr as i plan to turbo in the future. i have an 83 flat front ke70 i got some ma61 wheels the other day i have corona LCA's and cut and shut knuckles to go in but they will need to go when i put the motor in as i will upgrade the brakes, i will be just slowly getting parts together before i start doing anything but i just want to do as much research as possible as i will be doing the whole conversion myself. first off is the not so important but would like to know... speedo? is there a way i can get the standard speedo working or i was thinking custom fit an aftermarket one in or possibly even whole s13 dash cluster. tacho? i assume it is easy to get the standard one running but aftermarket is an easy option now important stuff with custom engine mounts will the motor fit straight in i have read that people had troubles but i have been told its a straight fit. thats about all for now cheers Report
May 31, 201016 yr comment_441388 Hey mate Just use an s13 engine crossmember, bolts right up. Rb engines use a mechanical speedo and ca/sr use electronic.but you can get speedo's from jaycar, build em yourself Other than that the hardest bit will be converting to efi Cheers Travis Report
May 31, 201016 yr comment_441390 s13 crossmembers cause geometry issues and put the engine quite far back. Fitting a 4age is an issue if your going turbo later on, as you will need to covert to a W box, make manifolds, get a ZE bottom end or change pistons and so on. With some reluctance I say get a CA18 or SR20. I prefer the CA18 idea more Report
