andy2004 Posted June 14, 2010 Report Share Posted June 14, 2010 ok so i just bought an sx corolla with 4age small port.now some dude has done quick home job on the pod filter.there are a few things hanging around i would love it if someone could identify these for me as i don't no how important they are. please help anyone? and this one is the lil blue plug thats not connected to somthing? this one is the little black pipe on top of the red air flow pipe and this one is of what looks like a sensor of some sort? Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted June 14, 2010 Report Share Posted June 14, 2010 ok so i just bought an sx corolla with 4age small port.now some dude has done quick home job on the pod filter.there are a few things hanging around i would love it if someone could identify these for me as i don't no how important they are.please help anyone? and this one is the lil blue plug thats not connected to somthing? this one is the little black pipe on top of the red air flow pipe and this one is of what looks like a sensor of some sort? Last one is the intake air-temp sensor, leaving it hanging around in the engine bay isn't a good idea as it'll be reading hotter than what the intake actually is - best to get a hole cut in the intake piping so that you can plug it in properly. Quote Link to comment Share on other sites More sharing options...
andy2004 Posted June 15, 2010 Author Report Share Posted June 15, 2010 Last one is the intake air-temp sensor, leaving it hanging around in the engine bay isn't a good idea as it'll be reading hotter than what the intake actually is - best to get a hole cut in the intake piping so that you can plug it in properly. brilliant that's one down. two to go thank you for that. Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted June 15, 2010 Report Share Posted June 15, 2010 The vacuum pipe in the second photo would go to the airbox as well, it appears to be headed towards the air-con idle-up valve on the firewall. Quote Link to comment Share on other sites More sharing options...
andy2004 Posted June 15, 2010 Author Report Share Posted June 15, 2010 The vacuum pipe in the second photo would go to the airbox as well, it appears to be headed towards the air-con idle-up valve on the firewall. o right could explain the high idling. should that pipe be blocked? Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted June 15, 2010 Report Share Posted June 15, 2010 o right could explain the high idling. should that pipe be blocked? Doubt it, depends on what is plugged up to the throttle body. Easy way to tell is to start the engine and block the pipe with your finger - if the idle drops, then it probably should be hooked up. 4AGEs run a funky vacuum switch on the airbox, pretty sure that line gets plugged up to there and the other side of the air-con idle goes to the throttle body. Quote Link to comment Share on other sites More sharing options...
