Things I Can't Fix With A Hammer So I'm Lost
i need some help identifying These wire's I'm trying to get my blinkers, all lights and Starter motor wired and I'm not getting power to anything dammit iv'e checked the battery and its fine
Here are some pictures
i don't really know what they are
The white one is defiantly live
neither of these seem to be live do these belong on the coil?
i don't have a clue what any of these are lol
number 1 is alternator charging wire.
2 seams like battery + to starter motor, little connector is for the solenoid
3 is coil
4 looks like headlight wiring?
correct me if I'm wrong please
so the alternator wire goes to the battery or the alternator?
goes from the battery + lead to the alternator by 2 small 4mm wires
ok cool do you have any ideas why I'm not getting power to any of my lights blinkers and how does the starter work? is it a big constant wire with a trigger postive wire?
Ahh and i also looked at the fuses they are all good
Edited by Chief
correct!
blinkers have a relay, check that.
does your brake lights work etc etc?
ahh ok i don't know where the relay is? nah no lights work at all and the battery and fuses are good what colour are the wire's for all that stuff on the battery positive?
Wow thanks altezza man and evan G i would go buy a manual but I'm short on money because I'm trying to get this working
Cheeers guys
Edited by Chief
something sounds very fishy!
check under the dash. look if that huge green connector is plugged in. check all the connectors are plug in
Yeah lol there was 3 big ones that weren't plugged in one was for the ignition key barrel thing the 2 other big long ones i also plugged in the plugs that are soldered to the ignition are any of them meant to have a current or they all neutral?
thanks evan
