rusty_starlet Posted August 19, 2005 Report Share Posted August 19, 2005 Hi, i'm looking at buying a 5k that i saw on trademe.co.nz to put into my KP61 starlet. it's got a dead 4k in it at the moment with a 4 speed. does anyone know if it's true you can't bolt it up to the 4k's gearbox? i was sure you could but i heard it wasn't that easy so i thought i'd double check. also is there a way to tell a 5k from 3 or 4k just by looking? and that's assuming it's not just written on the rocker cover or something. Thanks, hope someone that knows the answers will bother to reply. Quote Link to comment Share on other sites More sharing options...
TRD ke70 Posted August 19, 2005 Report Share Posted August 19, 2005 yip the 5k will bolt up to a 4 speed box, just use the 4k flywheel and clutch. and just check the engine number on the 5k it's under No 3 spark plug on the block, it should say 5k then the engine number. i use to have a kp60 starlet with a 5k in it so it can be done and it's not that hard. Quote Link to comment Share on other sites More sharing options...
Mr Revhead[RL] Posted August 19, 2005 Report Share Posted August 19, 2005 as above. where abouts in nz are you? Quote Link to comment Share on other sites More sharing options...
rusty_starlet Posted August 19, 2005 Author Report Share Posted August 19, 2005 i'm in rotorua Quote Link to comment Share on other sites More sharing options...
