July 12, 201016 yr comment_451169 I've asked a few mates about it and they don't really know. They of course taking the after market option. I was wondering if anyone could give me advice on it. Am i risking my life or is it safe as houses? Anything will help. Cheers in advance. Report
July 12, 201016 yr comment_451281 guess, you mean fitting wider rims to the stock centres. If so, yes I have done it a loooooooong time ago. Grabbed a pair of 13x6 Chromies cheap (made sues that the centres were welded in from the outside, not spot welded from the inside) and cut the centres out of them. Got a big drill bit and drilled out the spot welds on the Toyota rims and pulled the centres out of them. Fitted the standard centres into the wider rims and bolted them up to the car and spun them to check for alignment. Once ok, got a mate to weld them up. Not hard, just an afternoons work. Would I do it now, probably not. Report
July 12, 201016 yr comment_451317 Give new way wheels a call to redo wheels like that. A much better option! And there in melb. Report
July 18, 201016 yr Author comment_452737 thanks guys. think ill just have to get some cash stored and find some equip 01's love em haha. just thought it'd be a tad different to go with dished stock wheels. but with everything else its been done before haha. Report
