July 14, 201016 yr comment_451778 I have a problem i get static on my radio whenever applying brakes and when i turn the windscreen wiper on, the brake is hooked up with the parkers as well as the brake lights but that shouldnt effect it, maybe a unsheathed antenna wire? Report
July 14, 201016 yr comment_451779 Brakes and park lights are common because you have put one of the bulbs in back to front.. Report
July 14, 201016 yr comment_451788 Static would most likely be the supressor on the alternator.. Report
August 29, 201016 yr comment_463836 unscrew the antanna from the body check the screws for rust. clean or replace up u you. or alternitively you can buy a small device that wires into the head units wiring i think its called a noise supressor. :P Report
August 29, 201016 yr comment_463841 I have a similar prob i get TripleJ overrated on the Brisbane freq but static on the Sunny Coast freq. Pissing me off to no end. Original poster: Check your ground or main wiring. Or it's your power source. Report
