July 30, 201016 yr comment_455611 Gday Does anyone have any idea where the wire to the stock antenna is in a KE70? cheers Report
July 30, 201016 yr comment_455805 Where do you mean? In the dash? Mine goes from my guard through a boot in the fire wall, through Mordor and magicly appears at the opening for my stereo. If your trying to track it down inside the dash good luck. I suggest a torch and a chick with small hands. I'm pretty sure it pop's into the cabin up behind the fuse box but I'm not 100%. Just checked and i'm pretty sure the large wire up in that spot is the antenna cable. from there it just weaves its way through the dash I'm assuming. Report
July 31, 201016 yr comment_455823 Behind the radio is a good place to look As Medicine Man said this should give you an idea. Its the thick black wire :lolcry: Edited July 31, 201016 yr by "The Mint KE70" Report
