Converting 4afc To 4afe In Ae92
hi guys ive searched everywhere for this but have not had any luck :dance: . I'm trying to find a article step by step guides on converting my 4afc on my ae92 to a 4afe. i have a complete car to get the parts from. whats needs to be swapped over or is it not worth it? the whole car cost me $300, side damage to chasis but engine very good condition:) cheers guys
well you need to swap the rubber part of the fuel lines, fuel tank inc pump, engine obviously, engine wiring harness inc ecu loom, ecu and some minor stuff. It might take a bit of time to swap but not too far out of reach
yeah pretty much what sam sais.
since you have a complete doner car, that will make your job alot easier.
i suggest you just transfer everything over from the other car. fuel tank/lines/wiring.
pretty much anything that is differnet in the EFI car, put it into your other car. then you will be laughing.
it will be a bit of work (quite a bit of work actually.....), but just put both cars side by side, and as you take stuff off the doner car, transfer it straight to the other car. can't go wrong that way.
did a similar thing a few years ago with a mates st162 celica, bought a good condition, but smashed st162 SX (3sge) car. and just transfered the entire car (engine, brakes, suspension, wiring, fuel system) to the good shell.
started first time and didnt give any dramas.
