August 24, 201016 yr comment_462555 hey guy's, i am restoring a KE25 , to period spec's. looking for an ideal offset for 14 x6F and 14 x7R in rims. i have no flares fitted and will not be fitting them either. rims i will be fitting are Wantanabe's. thanks guys. Report
August 24, 201016 yr comment_462558 hey guy's, i am restoring a KE25 , to period spec's. looking for an ideal offset for 14 x6F and 14 x7R in rims. i have no flares fitted and will not be fitting them either. rims i will be fitting are Wantanabe's. thanks guys. sup rob? i just fitted some 13x7 +10 WORK equip 01's and they fit like this: Before low After low that is pretty much perfectly flush with the guard lips. should give you an idea of what fits best. keep in mind they are 175/70 tyres also. hope that helps Edited August 24, 201016 yr by twinkytodd Report
June 1, 201511 yr comment_697561 Alright it's been a while since I've played with offsets and I am looking to put 14's on my KE25 and have it sitting fairly flush. If +10 worked for you Todd then would +7 sit pretty flush as well? Report
June 3, 201511 yr comment_697627 I have watanabes in mine 14x6 +15 up front and 14x7 +8 on rear sit pretty flush with Guards. No flares and reset springs back and lowered ae86 coilovers front Report
June 3, 201511 yr comment_697630 This is before I lowered front and slightly lowered in 2nd pic Edited June 3, 201511 yr by Tenny0 Report
