4age
hi i been told by a few people on here to get a 4age engine in my ae80 corolla i went down to my performance shop and the say i can't because it to big for the engine bay was just wounding is he just saying that or is it true? also how much for the 4age engine?
He is an idiot, they are the same car with the same engine mountings.
so i can put it in awesome :) how do i go about getting one?
Keep an eye on ebay or your local paper for an AE82 twincam wreck.
could i try wreaking yard or best not try them
If they have one that goes then yes.
Just so you know, you will need the following:
Engine & gearbox (can use the SOHC box).
Brakes, suspension & drive system.
Wiring harnesses x 4.
Fuel pump setup, fuel filler & fuel lines.
Exhaust.
Brake master (supposed to have the diversion valve inside).
That is all I can think of.
oh that more then i thought i just thought i have to get the engine guess i start looking for all that then then get the engine
You now see why we said that it is easier to get a twincam to drive :)
true so what enigne can i get that wont be a pain to put in of anything if possible
4ac will be a slight improvement otherwise the 4afc.
so the 4ac and 4afc fit in with out changing anything
4ac is the larger to your engine not 100% sure what the 4afc will need but it uses the same fuel system, will have to check what brakes you have to use.
