Ke26... No Fuel Return....Why??
alright so I'm putting my 4k out of my ke70 into the ke26.... just had a quick look over and noticed that the 26 doesnt have any fuel return lines back to the tank....
I'm running a 32/36 on the 4k which has a return.... the question is what happens with the excess fuel if there is no return to the tank??? and what am i goin to do with the 32/36 which looks like it needs a fuel return??????
anyone else had this problem???
how did you over come this???
cheers for the help
luke
are you using the mechanical pump?
doesn't that need a fuel return line. :hmm:
well in the ke70 i had a fuel return so i had a electric fuel pump.....
I'm geussing ill be running a mechanical pump as it has the pressure cut off majiggy lol...
yeh i was just thinking of blocking the return.... I'm geussing the mechanical pump should have enough pressure for the webber
well when it goes in ill figure it out....
