4Agze Rwd Conversion... What Starter Motor? (Don'T Stab Me)
FNQ_rolla
no wont fit. the W box mount sits lower with 4bolts
a difference between fwd and rwd fork and release bearing is the width of the fork that pushes on the release bearing tabs. the fwd fork arms are thinner and wider from memory. it could be made to work with fwd fork, rwd release bearing, but the slop between them could be an issue :glare:
starter interchangeability... so long as its on the same side of engine and from another 4a then it should work. around ae92/ae101 they swapped from mounting on exhaust side to intake side and changed the starter bolt pattern to suit.
One of the best exhaust side starters is the redtop smallport which is smaller and more powerful with planetary reduction gear. If you want them to last longer, put a heat shield between it and the exhaust if not one already fitted. especially if turbo
