October 16, 201016 yr comment_476028 can't seem to find this anywhere on the web maybe someone on here knows does the 3sfe fit into an ae 92/3 corolla if so any mods? cheers benno Report
October 17, 201016 yr comment_476167 can't seem to find this anywhere on the web maybe someone on here knows does the 3sfe fit into an ae 92/3 corolla if so any mods? cheers benno You won't find any info because chances are no-one has done it. A 3SFE puts out about 90kw and is a fairly heavy engine, so for that amount of power you might as well just get a smallport or 20v 4AGE. If you do go an S-series engine, then at least go for a 3SGE, and leave the 3SFEs for SV21 Camrys and ST162 ST Celicas. Report
October 17, 201016 yr comment_476324 Nobody has done a 3SFE I've seen but there's been a few 3SGTE and 3SGE ones built. Look on toymods theres a jigsaw affair swap with only 1 custom mount with a gen3 3SGTE. Even mix and match CV's I think worked. As hiro said - it'll be a mission good 4age or a 4AGZE is alot easier bang for buck swap. Report
