October 18, 201016 yr comment_476392 hey guys iv been seaching for a while, on here on google and can't fine what I'm looking for, all i want to know is what do i need to get the motor in and driving cheers for anyones help. Report
October 18, 201016 yr comment_476394 a while is usually a term for longer than 20 seconds, scroll half way down the engine conversion page and woooaaahhhh find this http://www.rollaclub.com/board/index.php?showtopic=45204 same as putting a 3tc in ae71 pedal box - t18 can be modded to suit? ta22/t18 mounts onto a ke70 crossmember ae71 gearbox crossmember stock ke70 tailshalft should get you started, ask specific questions if you need anything else! Report
October 18, 201016 yr Author comment_476398 nah i used the seach botton and came up with 3tc wasnt sure if the same engine, but cheers for that mate Report
November 1, 201015 yr comment_479641 if i was to put a 3tc in my ke70 would a 2tg be hard to swap in later? like this may be a silly question but i figured that 2t and 3tc maybe have the same mounts therefore once the 3tc was in that a 2tg wouldnt be so hard to drop in? and has anyone here done/seen a 2tg in a ke70? also will the k50 work on a 3tc? I'm a bit confused! thanks in advance! Report
November 1, 201015 yr comment_479643 i also just read that you can put a 2tg head on the 3tc? wow, so cool! Report
November 3, 201015 yr comment_479925 yeah theoretically you could pull the 3t out and put the 2tg, but why not just buy a 3t and fly cut the valve reliefs and have a twin cam 3tg as you would call it, The thing you will need to put a 3t into a 70 is ae71 crossmember, t18 engine mounts and bobs your uncle Report
November 3, 201015 yr comment_479926 i forgot to add in that last post fly cut the valve reliefs on the 2tg head Report
November 3, 201015 yr comment_480103 yeah theoretically you could pull the 3t out and put the 2tg, but why not just buy a 3t and fly cut the valve reliefs and have a twin cam 3tg as you would call it, The thing you will need to put a 3t into a 70 is ae71 crossmember, t18 engine mounts and bobs your uncle twin cam 3tg :hmm:..... oh right ive got a 71 x member at home actually, id still need to mod a t18 pedal box though and put that in though? and would i have to get a t50 or something? sorry for the dumb questions! Report
