744ageke20 Posted October 23, 2010 Report Share Posted October 23, 2010 Hey guys,,just after some ideas for some suspension 4my ke20 but the shops here don't have 2much 2 offer so I'm lookin 4some ideas here if anyone has any i would appreciate them all. thanks . Quote Link to comment Share on other sites More sharing options...
13bke26 Posted October 23, 2010 Report Share Posted October 23, 2010 this is whats on my ke26, got an otomoto sleeve kit, with adjustable camber tops aswell Quote Link to comment Share on other sites More sharing options...
express Posted October 23, 2010 Report Share Posted October 23, 2010 pedders have a bit of stuff you could try them. Quote Link to comment Share on other sites More sharing options...
744ageke20 Posted October 24, 2010 Author Report Share Posted October 24, 2010 thanks guys,,,wats the adjusables worth ? and where from ? Quote Link to comment Share on other sites More sharing options...
13bke26 Posted October 24, 2010 Report Share Posted October 24, 2010 coilover sleeve kit is 299 and the tops are 299...not installed... tops have to be machined down and drilled to suit and the strut has to have the spring seats ground off and new sleeves welded on.. Quote Link to comment Share on other sites More sharing options...
rian Posted October 24, 2010 Report Share Posted October 24, 2010 ae86 struts maybe? ke20 tie rod ends apparently don't fit too well in the ae86 steering arms, too loose or something, but i'm sure there is an easy solution. Quote Link to comment Share on other sites More sharing options...
rockinrolla Posted October 27, 2010 Report Share Posted October 27, 2010 try some lowered king springs in the front, then find another set of rear springs and undo them, trim 20mm off each one, unpack the ones on the car, then repack but have the second leaf inverted, get a longer bolt for the center locating position, you may need a set of clamps as it gets pretty stiff, and hopefully it should turn out looking a little like this. rear shocks, try VH commondore wagon sports riders from pedders. Quote Link to comment Share on other sites More sharing options...
