rockinrolla
Everything posted by rockinrolla
  1. Buy another set of leave springs for a ke20 pull the pack apart and cut 2" off the ends of each leaf, pull your springs out of the 20 and separate them and repack them using the other one staggering them in order of length, make sure the second leads is inverted, bolt them all back together and put them back in the car, this effectively lowers the car 2" and doubles the load carrying capacity and stiffens the shit of the rear end, also its legal where as lowering blocks aren't.
  2. Which lcas are the longest and will fit a ke20 with R31 front struts??? Trying to get the right camber.
  3. Found R31 LSD rear end, my 13x7s fit on just. Now all I need is to cut it down to size, thanks guys.
  4. Just a quick one on the 7k engines, are the 7k valves larger than the 5k? If yes what are the measurements? :wootjump: :jason: :scarymovie: :bounce: :groupwave: :drinks: :drinks: :drinks:
  5. having the first main leaf normal the second inverted and the rest normal work just fine, if you want to stiffen it up and lower without blocks add extra leaves mine has a 9 pack with VH commadore station wagon shocks, it may sound to much but the leaves depth give the effect of lowering and extra weight carrying ability and the shocks are soft enough not to put you lower spine through the top of your head, had it that way for 6 years no problems and handles great, the front is standard struts with lowered kings and bump steer correction spacers, can send photos if you like, by the way did this all at home on my own to save money all up cost me approximately $350 and half a day. hope this helps. :bounce:
  6. What is the general thoughts from everyone about the pro comp range of ignition systems??????? :lovin: :lovin: :lovin: :lovin: :wootjump: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :kiwi: :kiwi: :kiwi: :kiwi:
  7. does anyone know the DOT regulations on side pipes? :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie: :scarymovie:
  8. any pictures??? :hmm: :hmm: :hmm: :hmm: :blinks: :blinks: :blinks: :blinks:
  9. $150 and I'm pretty sure it came out of an early :hmm: :hmm: :hmm: :hmm: :hmm: tercel
  10. there is a guy in melbourne, Peter robinson automotive I think, I Got a diff through him a couple of years back, 3.7:1 its in my ke20 right now and its awsome in 5th on the highway :yes: :yes: :yes: :yes: :yes:
  11. already converted the stud pattern to 114.3 and the diff ratio is 3.7:1, would really like to keep it and convert the drum to disc. i'll give the 86 disc idea a go and let you know, the hilux diff would be awsome, when you say "I got" is that anything like "I'm selling" !!!!!
  12. Question, What disc brake rear end do I use to I keep the 4 stud rear end and the 13x7 superlites, is this achievable??? :blinks: :blinks: :blinks: :blinks: :blinks: :hmm: :hmm: :hmm: :hmm: :hmm: :hmm:
  13. [b]Name[/b]: Isaac Macleod (11 3/4 Yrs old) [b]Car[/b]:ke20 (mini cobra) [b]Motor & Driveline[/b]:5k 3k X, twin asian carbies, 3" high filters, MSD, Jocobs HP coil, bosch Idrium plugs, 10mm leads, extractors and 2" high flow exhaust, the other picture is of the all alloy V8 Dad is going to help me put in. nedd more Cubes [b]Suspension & Brakes[/b]:front, lowered h/d king springs, 3/4 inch sway barand strut brace from VH bommadore and the rear is, VH bommadore pedders shocks, repacked(by me) leaf springs from 4 leaf to 9 leaf, custom rear sway bar from ke70, ride height(barely legal), Brakes are ke30 and 50 X. 114.3 pcd [b]Wheels & Tyres[/b]:13X7 superlites with 235/50/13 rear and 215/60/13 front. [b]Interior[/b]:Half cage and race seats and harnesses, the rest is stock. [b]Body[/b]:lowered, pumped guards with flares, white with Cyan blue stripes, fake FMIC, front lip spoiler, bonnet scoop [b]Other[/b]:suround sound system and 17" DVD player, 4X4 way 6.5", 2 X 6X9 4 way, 2 tweetwers with splitters and 12" sub and amp, Xplod head unit. *Put pictures here* Thanks Teddy! :)
  14. can you still run the 5k head with the 6cc pistons or not advisable, Just pondering another build and was curious :blinks: :blinks: :blinks: :blinks: :blinks: :blinks: :blinks: :blinks: :blinks: :blinks:
  15. FOR SALE 1989 740 TURBO VOLVO, GOOD FOR PARTS OR REBUILD FOR DRIFT OR FUN, NOT RUNNING, HEAPS OF SPARES AND CAN DELIVER TO BEAUDESERT AND JIMBOOMBA AREA $500 OR SWAPS FOR NEARLY ANYTHING MECHANICAL OR HOUSE HOLD ITEMS, would love a ke20 contact 0408252416, nathan
  16. Any luck with the sale? :blinks: :blinks: :blinks: :blinks:
  17. with the ke20, buy a 2 inch lowering kit, repack the rear springs with an extra 5 leaves and have the 2nd leaf inverted, be sure to grind the leaf springs to the correct length so none of then are the same length, staggered, do not use the actual lowering blocks, the extra thickness of the pack will do that, VH commadore wagon pedders shocks will fit. the front is a set of king springs 2 inch lower than standard, I've been running this setup for the past 3 years and it has brilliant,the weight carrying capacity is increased and is still reasonably comfortable. If you are unsure send me your phone number and I will send some footage to show you what I mean. :yes: :yes: :yes: :yes: leaf springs from any K series corolla will fit, I used springs from a ke55 and added them to the ke20
  18. It may sound stupid but, the 7k crank should fit into the 5k block, therefore eliminating the sump problem, what would the resulting capacity be, still just 1800 or ?, are the block heights different, if so different conrods will be needed, what would you have??? :hmm: :hmm: :hmm: :hmm: :hmm:
  19. try some lowered king springs in the front, then find another set of rear springs and undo them, trim 20mm off each one, unpack the ones on the car, then repack but have the second leaf inverted, get a longer bolt for the center locating position, you may need a set of clamps as it gets pretty stiff, and hopefully it should turn out looking a little like this. rear shocks, try VH commondore wagon sports riders from pedders.
  20. havn't had time to read the entire post pages but to have the fastest n/a 5k or 4k in the land would be an interesting challenge, as long as the were certain restrictions on what could be used ie, single carbie factory head but able to be ported and or flowed and or nitrous, it would have to be in a corolla of some sort also, weight reduction would be a must, I'm interested, one way to make use of all the spares lying around. :jamie: :bash: :D >|
  21. holy crap, keep it hidden, keep it safe, one sleeper to rule them all. :lol: :blinks: :blinks: :blinks: :blinks: :blinks: :dance: :dance: :dance: :dance:
  22. having tried both, top end they are pretty much the same but with fuel inj the low and mid rosponse is far better and more efficient, spend the money on an aftertmarket ecu and enjoy the overall difference, it is very noticable as you wiil find out. :yes: :D :D :P :( :yes: :( :( PS. try a new external fuel pressure reg, the ability to adjust the fuel pressure may help with your start ups and idle problems.
  23. yeah it has the water jacket hole and extra stud, I think the $150 gasket set is looking like the only option as I'm sick of making the bloody things, when I get them done I'll photo copy the actual gaskets and send them to anyone else that would like a copy, for something to have as templates if you want. :) :) :bash: :huh:
