Mikey Got A Dyno Run!!!!!!!
at the wheels..
max hp 54@?
max tq 76@?
don't know how to read them to find out when the peaks are, help?
factory ratings were: 59hp and like 75lbs AT THE FLYWHEEL
Edited by mikeys toy
I think the dyno operator started the run too early.. so the dip in the middle is probably where he changed gears. And whats this crap with plotting time vs power output. It should be RPM or wheel speed vs power output... Id just take the max figures down the bottom and use that
This is how a good dyno run (by a good operator on a dyno dynamics shooutout dyno) should look
at the wheels..
max hp 54@?
max tq 76@?
Then youve got more than 59hp at the flywheel when you consider drive train loss.
What mods have you got? My KE20 which was virtually stock (maybe a weber on it when i ran? don't remember) and had a very tired 3K ran a 19.56@ about 60mph on the quarter mile
yeah, he started the run too early is all, you should be in 4th (or whatever the 1:1 gear for your car happens to be) for any dyno reading
i would think 60hp from factory was a pretty over-confident estimate on toyota's part, it's probably less than that in real life, so you've actually done quite well
