November 7, 201016 yr comment_480817 AE82 Twinky. Did a gearbox swap. Speedo made a bit of a racket on first drive. Now ODO works, but speedo sits permanently between 180 km/h and off the clock. Any ideas? Report
November 19, 201016 yr comment_483297 in the week before i lost 5th and 4th gear my speedo didnt work. something to do with a borace bearing.. k50box Report
November 19, 201016 yr comment_483299 Where does the needle sit when the car is sitting still? If it's sitting at 180, take the face of and twist the needle around down to zero. Report
November 21, 201016 yr Author comment_483596 Where does the needle sit when the car is sitting still? If it's sitting at 180, take the face of and twist the needle around down to zero. Thanks mate, might give that a whirl. Report
June 6, 201115 yr comment_530057 any ideas for 78 3sp Auto with unworking speedo, ODO, petrol meter or temp guage? Cheers Report
June 6, 201115 yr comment_530058 any ideas for 78 3sp Auto with unworking speedo, ODO, petrol meter or temp guage? Cheers Is it even plugged in? Report
June 17, 201115 yr comment_532835 i had the similar - needle was stuck at 40k .... took it all out pushed the needle down to zero, sprayed a bit of white lithium grease in there and its been working fine since ...... Report
