machg Posted November 7, 2010 Report Posted November 7, 2010 AE82 Twinky. Did a gearbox swap. Speedo made a bit of a racket on first drive. Now ODO works, but speedo sits permanently between 180 km/h and off the clock. Any ideas? Quote
salvage Posted November 19, 2010 Report Posted November 19, 2010 in the week before i lost 5th and 4th gear my speedo didnt work. something to do with a borace bearing.. k50box Quote
jono1986 Posted November 19, 2010 Report Posted November 19, 2010 Where does the needle sit when the car is sitting still? If it's sitting at 180, take the face of and twist the needle around down to zero. Quote
machg Posted November 21, 2010 Author Report Posted November 21, 2010 Where does the needle sit when the car is sitting still? If it's sitting at 180, take the face of and twist the needle around down to zero. Thanks mate, might give that a whirl. Quote
Yellow78 Posted June 6, 2011 Report Posted June 6, 2011 any ideas for 78 3sp Auto with unworking speedo, ODO, petrol meter or temp guage? Cheers Quote
rian Posted June 6, 2011 Report Posted June 6, 2011 any ideas for 78 3sp Auto with unworking speedo, ODO, petrol meter or temp guage? Cheers Is it even plugged in? Quote
luke_ke Posted June 17, 2011 Report Posted June 17, 2011 i had the similar - needle was stuck at 40k .... took it all out pushed the needle down to zero, sprayed a bit of white lithium grease in there and its been working fine since ...... Quote
