Ke70 Wiring Issue. No Starter, No Interior Lights, No Indicators,
Hi Guys.
Got myself a new KE70 (old ones engine blew), now the new one has some issues
- car wont start when you turn the key
- no interior lights
- no wipers
- no indicators
it does have
- headlights work
- hazard lights work
What ive done to try and rectify the problem (I'm using parts out of my working ke70)
- replaced engine bay loom
- replaced coil
- replaced indicator/wiper stalk
- replaced key barrel (end bit)
- replaced fuse box under the dash
- replaced junction/fuse box on drivers side behind speaker kick panel
- replaced junction box on passenger side behind spearker panel
still hasnt fixed the problem
any ideas on what else i should check?
cheers
neil
Edited by xris
Sounds like a dodgy connection or fusible link at the Battery.
Should be a 3 pin connector coming off the positive battery terminal, That is the fusible link.
Make sure you have power getting through your fuse link..
Failing that, next step in the equation is the actual ignition switch..
yeah my ground cable was dodgy on my ke70 so much so it would die and then just start going again.. ha
all fixed. the black plug that plugs to the terminal had a broken wire on it. swapped the one from the good car in and presto all good. :) now to put the dash back together again lol.
