Engine Bay Vibrations Help Please! (Ke55 4Age)
Ok, soo I've got a 4age in my KE55, got the engine mounts redone so the engine is sitting level and the tailshaft is running true, but the problem is I still get vibration when I rest my foot on the accelerator gentley, and when I'm doing 110 on the highway, its better with tailshaft trued but I'm still have the vibrations from up front.
Getting rid of my rims so no more spacers as that was one part. But if anyone has had the same problems please tell me how or what was done to fix it, as
Thanks
wheel aligment wheel ballance maybe
tailshaft balance, not the wheels or else it would do it with no connection to the throttle
Edited by Sam_Q
He didn't specifically say when its in gear so it may not necessarily be the tailshaft...
You need to open the bonnet and slightly turn the throttle and see if the engines harmonic balance is out of whack. If the engine revs cleanly without the vibration then its definately in your rear driveline.
well he did say it does it when he is going 110, but your right he could be coasting
bent crank maybe :hmm: are ure tail shaft bolts all there and tight ect ect
if it was anything to do with the engine it would do it in every gear at the same revs
yeh got the tailshaft aligned like i said in post, the engine does rock, but only at idle which is not constant, and i don't think it has even with a tune. the throttle is pretty crap too, takes longer to go back to idle then my old mans cruiser, gets sticky sometimes, is it possible to swap the cable.
and sorry for the massive late reply
Edited by cozza_mane
