January 19, 201115 yr comment_496674 hey. i no its not corolla but i am having some serious troubles with the cam timing on my girlfriends n13 pulsar it has an 18le engine, and i do not no where to start, all i m lookin to do is set it to stock so i runs again? All help greatly appreciated and don't worry i do have corollas. a ke30 ke55 and ke70 :) thanks Corey Report
January 19, 201115 yr comment_496682 Should be the same as any other engine mate. I rebuilt my ex's N13 18l? years ago, too long to remember. Get #1 at TDC compression, adjust your dizzy, might be a tooth out, try again, and adjust your dizzy. Is it the timing gear or the dizzy thats out? Have you got a timing light? Report
January 19, 201115 yr comment_496683 need an engine number or code to be any help!! Its the 1.8 litre 18le sohc EFI they put in the N13 pulsars. Report
January 19, 201115 yr comment_496685 there is two different tensioners in them!! Year would be good too!! C18NZ should be the engine number!! i have the diagrams, just need more info. Edited January 19, 201115 yr by TRD ke70 Report
January 19, 201115 yr Author comment_496687 its 1989 model pulsar vector SOHC, 8 valve, do you need any more info? Report
January 19, 201115 yr comment_496688 there is two different tensioners in them!! Year would be good too!! C18NZ should be the engine number!! i have the diagrams, just need more info. Ah righto, i didnt realize there were different engine models. Report
January 19, 201115 yr comment_496692 The engine code is on the block in big letters, there is actually 4 different engines for that model. But the timing belts look to be the same across the models, just a difference in if it has a manual or auto tensioner. Anyhow here are the timing belt diagrams, you have the engine in front of you so you should be able to work out what you have. Timing belt with auto tensioner.pdf Timing belt with manual tensioner.pdf Edited January 19, 201115 yr by TRD ke70 Report
January 19, 201115 yr comment_496698 Simple. I've had some practice at this. Put a paper clip into the A & B terminal to bridge it in the diagnostic plug. From memory, one wire is black & the other white. (collingwood). This put the computer into self diagnostic mode. Thermos come on and the ECM light on the dash flashes. You can also check the engine fault codes. Now set timing as per normal 10 deg BTDC. I've had a couple of these. http://www.rollaclub.com/board/topic/44080-the-blood-blister/page__p__459891__hl__pulsar__fromsearch__1#entry459891 Report
January 19, 201115 yr comment_496706 Thanks TRD Kinda hard to tell what he needs. Ok, cam gear mark should be at the top, aligned with the mark (funnily enough) For the crank, dummy fit the pulley and align the timing mark with the pointer, at 2 o'clock. Adjust with the water pump. Correct tension is when the belt can be turned 90 degrees, halfway between the camshaft and water pump. Bamboo Report
January 19, 201115 yr comment_496715 thanks heaps for your help. Forgot to add, If the water pump seal isn't new or near new, when you adjust it, it will bloody leak. Usually replace the pump when doing a belt. Also, a camira pump won't fit, as the pump nose is too long. Good luck. Report
