Problem. Engine Wise
Hey guys
Thanks for your help. I'll go hide in my noob shell and read the manual :unsure: But seriously I'll go do some reading, my explaining skills are very poor. and I'll buy an engine lol.
Thanks
Troy
the socket you used, is it a 6 or 12 point?
depending on how bad they are... sometimes you can clean up a rounded bolt head a bit and then get them out with a good 6 point socket. or maybe even a metrinch socket as they put the force on the flats of the bolt head hex, not the corners.
I used a 12 point. This might turn out to be a good thing....get the 4k out and actually put some $$ in for a conversion.
Thanks
Troy
Before you go all out on a new motor, give it a chance by using a 6 point socket, so it can get a grip on the bolt head some more. No point wasting the whole 4k when you didn't even bother trying something different... And I think that if it were to be metric it would be a 14mm, is it 9/16 Imperial that you are using? Or maybe your socket is f@$ked?
Cheers,
Dan.
Sweet I'll give it a try. See that's the thing, with the 9/16 I tried it didn't fit =) So I tried the 14mm so I'm going to assume they may have been replaced :(? Going to get some multi grips on to it.
Thanks
Troy
Noooo... not the Multigrips!!!
9/16 and 14 mm are almost the same, did you try 11/16 or 15mm or?
