February 14, 201115 yr comment_502985 hey guys, just want to check if it is possible to run ae86 powersteering arms with xt130 struts, brakes and lca's in a ke70? i have heard some say it works and some say it doesn't so i would just like it cleared up before i buy these parts thanks Report
February 15, 201115 yr comment_503160 You may have to grind a small amount of the end of the lower control arm if you have bigger discs. The PS arms have Neg camber offset in the casting and the back of the disc hits the lower control arm. The Neg camber can be compensated by getting the XT130 lower control arms. Edited February 15, 201115 yr by Crostek Report
February 15, 201115 yr comment_503165 You may have to grind a small amount of the end of the lower control arm if you have bigger discs. The PS arms have Neg camber offset in the casting and the back of the disc hits the lower control arm. The Neg camber can be compensated by getting the XT130 lower control arms. xt130 arms give you a lot less lock though. Report
February 16, 201115 yr comment_503446 the XT130 steering arm will give you less lock yes, you are using the AE86 Power steering one? the XT130/RT132 lower control arm will push the ball joint out by 10mm or so reducer the positive camber in the AE86 power steering arms. see how the middle steering arm "AE86 PS" has the hole closer to the bottom/outside of the arm. and how the middle lower control arm which is the same as XT130 and RT132 is longer then the top KE70/AE71 one If you do a search you will also find out that you will need to goto RA40 tierod ends and tierod tubes to have the right lenght to do a wheel alignement. I have all these bits myself going into a KE70 if I don't sell it soon! Report
