Ke55 With 2Tg Wiring
hey guys i got a ke55 with a 2tg in it, now the problem is i gotta rewire the car, and i need a new loom as there is to many wires that a burnt and broken, now i need to find out what loom u would use on a 2tg, would u use a ke55 loom and just rewire couple of wires?
That's what I would do. Assuming you have a carby motor and not a injected motor.
Even if it was injected, I don't see that you have any other option anyway.
Realistically very little will be different between the two types of motor (K family to T family), that a bit of shortening or lengthening won't fix.
Edited by parrot
ahh k yeah sweet, i pulled a loom out of a ke30 two door but its different to the ke 55 hmm any1 sellin a loom
better off just getting another 55 loom, saves time and money, there is bugger all you have to change for it to hook up to a 2tg.
yeah ill go with a 55 loom the problem is findin onr
ey people need help to identify what loom ive got, ive checked so many corolla ke30 ke55 and non are the same, under the dash it 2 white plugs the big plug is a male plug, and there is 19wires at the firewall,
every corolla ive checked all hav a white and green plug?
