1Jz Gte Or Similar Into Ke55.. Possible?
hey,
was considering dropping the 4k turbo idea and going for a little bit more power ;) want to know if anyone has put a 1jz or 2jz into a corolla before or thinks it will fit
any advice or help is appreciated
thanks
It could be done but honestly whats the point? Unless it's a drag car then there's not point as it'll handle like crap.
Everything would have to be upgraded, clutch setup to hydraulic, pedal box, diff, brakes, transtunnel etc..
Then there's loom, mounts, gearbox mount, tailshaft, diff mounts etc etc plus suspension upgrades if you want to even remotely handle
Its been done many times to early KE corolla's. Will need modification to almost everything though. And yeah, ^like he said^, have a quick search.
