February 28, 201115 yr comment_506431 original problem moved to second post, these HotWires have been painted gold poorly by previous owner. i've started scratching off the paint but considering using paint stripper between the "wires". what's stopping me is i've heard the stripper isn't good for the wheels so can i us it or how would you recommend fixing the paint. Edited March 31, 201115 yr by dzach23 Report
March 7, 201115 yr Author comment_508163 i've just test fitted hotwire wheels to my corolla, and have come across this problem. their is about a 7mm gap between the wheel centre hole and the hub Edited March 31, 201115 yr by dzach23 Report
March 7, 201115 yr comment_508173 yep. you can get spacers that fill up that gap. little rings. go have a chat to a tyre shop, they should be able to sort you out. if not, find your local machinist, he will take a few measurements and be able to machine some up for you. Report
March 7, 201115 yr comment_508203 hub ring spacers they transfer the load to the hub centre of the stub axle Report
March 7, 201115 yr Author comment_508278 thanks Mungi and Dave for the replies another quick question should i use the washers with the nuts? Report
March 8, 201115 yr comment_508616 The centre hole is to locate the rim correctly not carry the load. With countersunk wheelnuts you can get away with a gap like that as they will self centre anyway, but your wheelnuts aren't countersunk so really you want a hub spacer ring Report
March 10, 201115 yr Author comment_508924 i have this lock nut but the diameter is just to big to go into the nut hole, any ideas on how could reduce the diameter enough to fit, i'v tried the bench drill but it's not big enough to hold the nut??? any ideas Report
March 10, 201115 yr comment_508941 A machinist shop could put them in the lathe and turn them down to size in 10 minutes or so Report
March 11, 201115 yr Author comment_509352 possibly the last question for these wheels, in first post Edited March 31, 201115 yr by dzach23 Report
March 31, 201115 yr Author comment_513989 more help needed, 1'st post has the problem Edited March 31, 201115 yr by dzach23 Report
