rolla9669 Posted February 28, 2011 Report Share Posted February 28, 2011 hi , does any one know about why my dash lights in my ke70 don't work , checked all the fuses , all 3 fuse boxes and can't find any broken ones , is there a inline fuse some where , there is no power going into the dimmer switch , every thing else works , but no dash lights , thanks , mic . Quote Link to comment Share on other sites More sharing options...
rolla9669 Posted March 1, 2011 Author Report Share Posted March 1, 2011 hi , the fuse for the parkers was blown , replaced that , but they still didnt work , it was the back of the dash was blown , got anyother dash , and all works now , thanks . Quote Link to comment Share on other sites More sharing options...
mat_jey Posted March 9, 2011 Report Share Posted March 9, 2011 Hi there. I'm having the similar problem as you. I was once working on my dome light that is not working. I don't know what in the hell I'm opening all my meter and dash for it :happy: and managed to get my dome light working again. All of the sudden, one wire got short circuit and all my dash, my tail light, my front small side light are not working :glare: I've checked all the fuse box (3 places), under the dashboard near to steering column, underneath and near to throttle pedal, and inside the engine bay near the battery. Been checking all the fuses many times but non seems to blow. But still can't get my dash/meter light to work again :bash: Since you happen to get it working, mind showing me if there any hidden single fuse that I should look into? Thanks in advance ~ Quote Link to comment Share on other sites More sharing options...
Heath. Posted June 20, 2011 Report Share Posted June 20, 2011 same problem here to man. dash lights and fuel and temp gauge do not work! god dam it! and also my little door light doesnt work either? and you said there were 3 fuse boxes...... engine bay, bottom right of the dash but where is the 3rd one?? anyway i have changed my fuses all before and even the bulbs inside the dash too. could it actually be the dash itseld? cause i have another lined up but i wanna see if this one can be fixed before i buy another.. Quote Link to comment Share on other sites More sharing options...
mat_jey Posted November 26, 2012 Report Share Posted November 26, 2012 Oh my.. why didn't I get the notification for this post. Anyway, sorry mate for a late reply. The three fuse boxes were: #1 Under the dashboard. #2 Down under the Throttle pedal. It store inside the Door main panel, behind the fender inner. #3 Inside the engine bay, near the battery Regarding my problem in earlier post, I found out that the cause to it was a 'Blown Fuse'. Initially, during checking.. I was just pull out the fuse and inspect it using what I can see inside the fuse. The filament didn't seem to be broken, and I assumed it was ok. Didn't solve my problem either. Double checked everything and this time I've checked each and every fuse using a "Multimeter" and bam! Got 1 fuse blown. Replaced it with new one.. and everything back to normal ;) Quote Link to comment Share on other sites More sharing options...
easyvision Posted November 27, 2012 Report Share Posted November 27, 2012 Just a heads up for anyone else, I did the old' - not plug the dash dimmer nob plug in after pulling my dash apart. fixed that pretty easy. Quote Link to comment Share on other sites More sharing options...
