October 20, 200521 yr comment_78086 BLOLUX......twin turbo V8 Toyota Hilux Engine HSV VT 304ci Stroked to 355ci 20PSI Twin Turbochargers. Mick's Metal Craft Inlet Manifold, Intercooler And Plumbing. Autronic Fuel And Ignition Computer. Dual 3.5" Mandrel Bent Exhaust With Dual 3.5" High Flow Catalytic Convertors. By Blolux Engineering Transmission Hugo Race Glide. Full Manual Shift. 2700RPM Stall Convertor. Differential Shortened Ford 9" From An XF Fairlane 4.11:1 Gears And Full Spool For Racing 2.75:1 Gears And LSD For Street. Wheels and tyres American Racing Torque Thrust II 20" by 8" With 255/35-20 Pirelli P-Zero's American Racing Torque Thrust II 20" by 10" With 285/30-20 Pirelli P-Zero's Brakes 387mm by 38mm Slotted, Cross Drilled and Ventillated Disks. 6 spot AP Racing Calipers 338mm by 28mm Ventillated Disks. 4 spot AP Racing Calipers Suspension Koni Shock Absorbers, Nolathane Bushes. Four Link Rear End With Watt's Linkage by M&A Engineering. Spax Coil Over's Paint Chrysler Red Inferno. Interior By KAM. Custom Dash, Retrimmed Recaro Seats. Rollcage by Micks Metalcraft Engineering John Wilson. click here for full details this car has been built by my mate Travis.. i am hopefully getting him to turbo my hilux early next year.. and then some work on the old ke20..... Report
October 20, 200521 yr comment_78087 what on earth does he intend to do with it? a mate of a mate around here has a v8 hilux as well, a green trayback which is a former summernats burnout comp winner. now running an AU windsor with 13:1 compression and 300+ degree cams Report
October 20, 200521 yr comment_78092 I could use one of these BloLux Specials for work :harhar: I'd never be late for installation on site!!! Report
October 20, 200521 yr comment_78112 I could use one of these BloLux Specials for work ;) I could use it for creating my own weather systems, and envoking global climate change... :harhar: Report
