November 1, 200520 yr comment_80625 irokin in the top of the bigport manifold the carby ports are almost equal. will a non bigport carby bolt on and be used or is it best to keep the bigport carby??? Report
November 1, 200520 yr comment_80630 As far as I remember the carbys were the same size. The manifolds looked the same from the top. Youd be better off with a weber anyway :jamie: Report
November 1, 200520 yr comment_80633 singlecarbs are all the same size, it's the manifold runners that are different. all manifold bolt across all heads Report
November 1, 200520 yr comment_80635 i was also meaning the butterflys in relation to the ports. non bigport has one larger and one smaller. bigport head carby has equal ports. well mine does Report
November 1, 200520 yr comment_80636 not quite, but full marks for noticing there are two different types of aisan carbs K and 3K carbs have 27/27mm throats 4K carbs have 27/32mm throats, but vac sec bigport manifolds are only 3k-sized, but you could hog one out to suit a 4k carb if you wanted Report
